Trace: Exact Trace vs Vague Trace
Something I've noticed for a while is that when I use the Trace function sometimes it traces the item perfectly and other times it is really vague, smoothing over and skipping small areas and points. What might be the reason for this?
While on the subject of Trace -- does the Trace command not work on objects/polys that have been Grouped? I believe I've encountered that, too. And if not why is that? Are polys that have been grouped together not still polys? Just curious as to the inner-workings.
Thanks, as always, Monsen. Always a fount of information.
You'll find that there are multiple things that work differently when entities are grouped. Personally, I usually don't use groups at all.
