Issues with CD3: Upside Down Fills & Random Street Not Working Properly
ScottA
Surveyor
I am having a couple odd issues with CD3. First off, fills, when applied to buildings, are upside down! I'm using the Jon Roberts city and imported a couple roof fills from CD3, and when I apply them to buildings generated by the Random Street or that I build with the House button, they are upside down! This also happens with the fills that are already in the Jon Roberts pack. Regardless of the building's orientation, this happens. Is there a way to flip the orientation of fills? Or is there a solution to this issue?
Second is the Random Street. It is not working. When I click on a street nothing happens. Or, when something does happen I get a couple buildings placed randomly along the road! This feature was working perfectly well two days ago, but as of yesterday, it began doing this. I'll attach a couple screen caps to illustrate.
A road the I tried to use Random Street on. I did each side and this is what I got -- a few on the left and then a few more on the right on the second try.
Should I just re-install CD3+? Apparently, that addresses the upside down roof issue? But what of the Random Street? Same? And if so, should I then re-install the recent Random Street update from the annual? Sorry... as I've said previously, I'm a big dumb dumb when it comes to some computer/tech things!
CC3 vs CC3+ installs doesn't really matter, because these are 100% separate. Installing CD3 in CC3 and CD3 in CC3+ are completely separate, and don't affect each other in any way (and thus, both needs to be updated with the latest CC3/CC3+ update individually as well).
I recommend you just grab the latest CC3+ update from your registration page and install it. I am unsure about the random street thing, I can't remember any bugs with that feature. As for the Random City command from the annual, you don't need to reinstall that.
If you have, both, CC3 and CC3+ installed, it's possible that you may have accidentally installed Update 11 for CC3, which is the last update for CC3.
EDIT: It appears that Update 13 has been slightly tweaked to update to 3.79. The change was so minor that the file is still called Update 13 but if you have version 3.78, you may want to re-download and re-install just to get the absolute latest version.
You know what? I think that's what I did. Update 11 is at the bottom. Update 13 is higher up and I didn't even see it! And it's not in my ProFantasy software file, so that is exactly what I did! Zoinks! Big dumb dumb!!! LOL! Thanks, Dogtag. And thanks, Monsen!!!
Glad to know it was something that simple, Scott. Map on!
Cheers,
Thanks Monsen For doing this.
