Cannot change properties on walls in DD3 without deleting floor sheet
I'd like to change the width of the dungeon walls. So far I've been:
1) Hide all sheets except WALLS,
2) Clicking on Change Properties,
3) Selecting all walls with pick cursor,
4) Right click and select Do It,
5) Change line width & hit Ok.
Which works, except my floor sheet disappears!
a) your Floors are on the WALLS sheet. Are they visible when you've hidden everything except the WALLS sheet?
or
b) they are grouped together with the walls. Any changes if you UNLOCK groups before doing the width change?
Or did I misunderstand and the actual sheet in the list disappears? It might help if you post your map here.
