How to use a CD3 fill style in CC3?
I have been messing with CC3 a bit (yep, trying some overland maps again) and I have a question.
While creating an overland map I want to get access to the CD3 fill styles. Unfortunately I am stuck with just the CC3 fill styles, as you can see in the screenshot, when creating a new drawing tool. How do I access the CD3 fill styles while creating an overland map? I want to use some of the grass textures of CD3 for example.
  • import them into the map using tools> import bitmap fill styles> then browse to the folder containing the fill styles you want. I find it best to copy only the specific fills you want into a kind of holding folder because you get every fill in a folder imported even if you select a specific fill , and it does not import from any subfolders.
    Do a Draw > Insert File and import the CD3 bitmap fill list. You'll find it under under CC3\System\Fill Styles\. After that, you'll habe all CD3 fill styles available in the map.
