Troubleshooting: Printing PDFs
Thank you for clicking.
I cannot seem to print my map at full scale across several pages. My friend has a 60" wide printer, so I would like to print a very large map, but I can't seem to save it full scale as a PDF. I'm sure there's a way to get it to work. When I use a PDF printer driver, it only generates a blank PDF at 11kb. I'm sure the file I want will be substantially larger than that.
Any help is quite appreciated!
-Township
-Township
This discussion has been closed.
http://forum.profantasy.com/comments.php?DiscussionID=735&page=1#Item_2
Note that if you find yourself posting in the wrong category, all you need to do is to edit your original post, and you will be able to change the category it is placed in.
If you have already created a duplicate post, please delete the wrong one immediately, so we don't have two identical posts floating around.
The controls for editng and deleting your own posts should be in the top right corner of each post.
