Community Atlas - Manor
Sue gave a link to the drawing below, and I was so taken with it, that I decided I would turn it into a CC3+ map, and put it in the Atlas. The question is where. I need a feudal type society, and someone who has already drawn a regional map I can fit it into. So while I do this map, can you put your thinking caps on and make suggestions. That includes the Magnificent Monsen and Dogged Dogtag.
Out of curiosity, why do you need the larger maps (i.e., continent, regional, etc.)? Why place those limits on yourself? The manor is small enough that it should be able to fit into nearly any regional map. In fact, why not just do what the original map does and make it a "typical feudal manor" map? That way anyone using the atlas could just plop it down in any other map they choose? The Forgotten Realms Interactive Atlas (FRIA) did this with some of it's maps, to great effect.
Just my two cents.
Cheers,
I can't remember who it was either.
Just checked - it was Barliman
I gave a link to an aerial photograph of Portland Bill, taken by the Luftwaffe in the early stages of WWII
Also, I would image that the manor house would be on the high-side of the stream, looking down on the village and the minions toiling there.
Tim
Personally, I would consider experimenting with a bit larger scale for the forest textures, thereby making the trees a bit more obvious, and the texture repeating a bit less.
I think the forests look much better now with the new scale, and I also like the fonts better. As for the fonts though, did you make sure these are either standard windows fonts, or fonts installed with CC3+ or addons? Otherwise, most users will only see a plain replacement font, including me when I render it.
