Problem with Annual 126 (city generator)
When I install the annual and run cc3+ it tells me I need to install Net Framework 3.5 which fails when I try. Then it errors out on two files cc3actions.dll and cc3generator.dll. I am guessing these are the files that run the city generator. What can I do to fix this? I know the problem comes from installing the annual because when I uninstall it CC3+ works normally. Is their something in the installation that I am not doing?
I'm not sure how to investigate this issue.
The most common reason for those tho dll's erroring out is that they can't be loaded because they require a version of .net not present.
Windows 10 should automatically detect this and offer to install the required version automatically, but I don't think any earlier versions do.
I installed it manually, and it now works.
