Two CC3 maps and question.
Having bought and installed CC3, Life got in the way, but I have now made a couple of maps. I could only attach one to this post, so will post the second shortly. These could clearly be much improved artistically, but as a reference for players they do the job. On the first one (Coranan) how can I display the grid without the refernce numbers showing. I did turn them off before I started the map, and they are still "off", but remain as seen.
Bonzer
  • 6 days later
  • JBMJBM
    edited February 2009
    Did you create the grid on a seperate sheet? If so you should be able to delete the grid with little problem and be able to re-enter it. However, when you do it this time ensure that you uncheck both the LABELS OUTSIDE check box and the main LABELLING check box on the HEX/SQUARE Grid dialog box, before pressing Apply. I just tested it on one of my maps and it worked fine.
    Nice map by the way!
  • 13 days later
  • By the way, nice map! If I were a player I would be impressed.
