Crashing when using Alpha blur in conjunction with Bevel
I was trying to get an ordinary unlit bevel to work properly without any of those little triangles you sometimes get, and trying out various different combinations of sheet effects.
I applied an Alpha blur effect above (before) the bevel and clicked Apply. It worked - the bevel was totally and absolutely spot on perfect, but when I clicked ok CC3 crashed.
I tried it 5-6 times with the same result. Is it my map that's the problem?
The map in question is my Scribble Rock map, and I solved the problem by using shaded polygons instead of the bevel effect, so I don't actually have the one with the bevel in it to show you - sorry!
