Bitmap Tiles As Fill
I know how to set bmp tiles as fill on a map, but is there a way to permanently add bmp tiles to the drop-down fill menu so that they are always just there as a choice so I don't have to create and add them each time I want to use tiles as fill on a new map?
    You can insert a bmp or png into any map fcw file being edited. The Insert File is under the Draw menu at the top of Cc3/CC3+.
    I don't do much with the menus. Likely someone else can do a detailed reply on that.
    A map inherits the fill style definitions from it's template, so by adding them to a template, all maps made from that template will have these styles. There are no global way to add them to every map/template though, you need to add them to each template where they are relevant.
