Fractalization problems
Lorelei
Betatester 🖼️ 46 images Mapmaker
So, it seems that whenever i try to use the Fractalise option, no matter what settings i use, as soon as i hit OK, CC3+ shuts down. EVERY SINGLE TIME. No matter, new map or old. I've tried to do a repair of the last update, but that doesn't seem to be helping. Any thoughts?
In the meantime, I recommend using the macro version as a workaround, simply type FRXM on the command line to run it. You'll need to provide the values on the command line instead of through the dialog, but other than that, it is basically the same.
(In a related note, that was really cumbersome to test from my phone)
