Hotkeys for CC3+
Is there a list of command and the hot key equivalent? I have a fancy mouse, and I'd like to map some additional commands to the buttons on my mouse. Some desired examples would be, info list, delete, change properties etc..
There's also a list of all the text commands in the Tome, if you have that, you can probably feed your mouse the actual text command instead of just a shortcut key (You can also see these text commands in the menu files if you don't have the tome)
