Dotty fills
Loopysue
ProFantasy 🖼️ 41 images Cartographer
Hi All
Just rustled up a couple of transparent PNG fills for you (to follow). This kind of pattern fill is really easy to make so if you want one just ask.
use and share, but not for resale
[Image_7868]
[Image_7869]
[Image_7870]
[Image_7871]
[Image_7868]
[Image_7869]
[Image_7870]
[Image_7871]
 vertical.png)
 diagonal.png)
Looking at it makes me see weird things that aren't there:D
You may find that you can't use any edge fade on these, so they might not be as useful as you would want them to be.
@ TSRThomas - Is this what you were talking about?
EDIT: just to clarify - because these are transparent fills the edge fade inner sheet effect will work on all the dots individually, rather than just the edge of the polygon.
However, I'll keep in mind not to use them with an edge fade inner effect.:)
I did these primarily for TSRThomas, who was asking about how to do transparent textures on top of coloured fills in another thread, but then I decided that they might be of use to anyone really - providing all are aware of the edge fade inner snag
T
I'm thinking I should delete them as a health hazard.
Just to prove it here are some less regular ones:
[Image_7878]
And if you need something peaceful to look at afterwards here is some grass Genetica gave me. Its one of their library files - free to all for any use... (with the possible exception of reselling as an entity in its own right... which would be pretty pointless anyway because you can get this and many others free from their website).
[Image_7879]
