Exporting and resolution options
Hi all,
I've read the FAQs and performed some searches, but haven't been able to find specifics on CC3/CC3+ export & resolution options.
Long question short, can a map be created at a size & resolution that will look good exported to a poster size? Say... 2'x3' or even larger?
Thank you!
Thank you!
This thread may be of some use.
(You can also export the map manually in pieces to get a greater total size. Generally, this works fine, but some effects may get cut of at the edges of each piece )
