Perspectives 3 and Holes
I've created a floorplan in perspectives but I need a staircase to descend through a hole in the floor. I've used the 3D Cylinder with a negative value to make the hole and it looks great! What would be the best way to get some stairs going down around the outer edge of the hole? Symbols don't seem to work quite right for this. I've attached a picture for reference, thank you!
If you are prepared for a little extra work and an additional set of sheets, you can cover up part of the stairs by a floor on the next "level". See the attached example.
