Grid Labels - Outer Grid Label Issues.
Hello all,
I am using CC3+ as of today fully patched (v 3.75).
When I create a grid i choose outside/outer labels and a square grid.
When the grid appears the outer labels look great. However when you zoom the map or refresh/redraw they disappear. Also they don't appear in exports or print.
Also if you make a large grid say 100 x 100 cells they don't appear at all even from the start.
Would be nice not to manually place them on the map.
Any ideas?
Kind regards,
Jason
    Most map templates aren't set up for outside labels by default.
    What happens is that the numbers get hidden by other elements, either by the map border, or by the whit screen just outside the map border on many templates. Since the numbering appears on the same sheet as the grid itself, the basic fix is to move the GRID sheet to later in the drawing order, after the MAP BORDER and SCREEN sheets.
    You could also manually move these numbers to another sheet after they have been created, leaving the grid where it is. This require you to unfreeze the HEX/SQUARE grid layer, and turn off group locking.
  • Thank you for your reply Monsen, it's appreciated.
    Jason
