I would just use a smooth polygon with a dirt fill. There should be several different dirt fills in the template. Then apply an edge fade effect to it to make it blend in with the terrain below.
If you have effects on, try to turn them off. It is often difficult to hit the correct spot on a faded edge. Also make sure it isn't on a frozen layer.
