I can't install CC3
                    Hi everybody,
I just bought the CC3, CD3 and DD3. I've downloaded and installed the programs in this order: CC3, patch 11 to CC3, CC3+, CD3 and DD3. While I was taking confidence with the software environment and after taking a look to some tutorials on youtube, I noticed that the Dungeon Designer 3 icon were not on the upper bar (as I haven't installed it at all). I looked at the addons menu inside the program and there was no trace of DD3. I installed it again but I had same result. So I uninstalled all the programs, removed the folder manually after uninstallation and started again. Now I can't install CC3 because the program stops to working after I accept the software conditions. I tried even to download it again, but I have the same result. Any advice? Thank you.
- You say that you installed both CC3 and CC3+, did you also install the DD3 versions for both? If not, did you check for DD3 in the correct program (CC3 or CC3+, depending on which version of DD3 you installed)?
- The installer hang happens because the registry entry sometimes gets corrupted. Delete the HKEY_CURRENT_USER\SOFTWARE\EvolutionComputing registry key (Be careful when editing the registry)
1. CC3 and patch 11
2. CC3+ and patch 9 (the last and only one I Can download from my products page)
3. CD3 (for CC3+)
4. DD3 (for CC3+)
Or do I have to install CD3 and DD3 for both version of CC3 and CC3+?
