Inconsistent Grids
Hi Team,
I seem to keep facing a reoccurring issue with Grids where the clarity of the grid does not remain consistent throughout the entire map.
This is driving my OCD side nuts. Is there a known fix for this?
Example: https://drive.google.com/file/d/0B_6BXlzLTlj8U2xfTTV6NEdWRXM/view?usp=sharing
Also check the effects on the grid, transparency and fade effects will also cause it to vary depending on the entities below.
This is live in the tool with the transparency removed and a line width of 0.05
https://drive.google.com/file/d/0B_6BXlzLTlj8OVNyZW4wckotMUE/view?usp=sharing
This is live in the tool with the transparency removed and a line width of 0.1
https://drive.google.com/file/d/0B_6BXlzLTlj8Si1fdnNzYmNsdG8/view?usp=sharing
There's definitely something not consistent with the grid line width.
Another option which can help is to have a soft glow black on the grid, this makes them stronger and more pronounced.
Note that all this is because of the fact that CC3 doesn't work in pixels. This gives great flexibility and quite a lot of advantages, but it also has the downside that everything needs to be rendered to a pixel format, for screen, for image export and for print. This can cause various forms of artifacts, usually because the number of pixels available aren't evenly divisible by the size of the features in CC3+. Sometimes, a grid line may be centered on a row of screen pixels, making it appear exactly one pixel wide, whil at other times it may be placed exactly in between, causing it to "take up" the pixel rows on both sides, making it appear two pixels wide. This is something that pure raster programs doesn't have to deal with, but it also limits them.
How are others dealing with this situation, especially for maps needing to be printed?
If I make smaller maps it's not an issue, the problem is when I make a larger map.
Thanks!!!
