Cut hole in the floor...
Hi Team,
Let's say I have a multi-level building. Is it possible to cut a hole in the floor?
I want to add a replica of the bottom floor underneath the current floor hole...
I bet it's possible... and likely relatively easy... for you guys
You can use a Colour Key sheet effect and draw the hole as a solid polygon of the same colour as the colour key on the same sheet as the floor... or you could create a multipoly by drawing the hole and mutlipolying it with the floor using the multipoly tool. The first is a bit inconvenient if you work without the effects turned on, but its easier to edit than a multipoly.
To add the collapsed floor below the one with the hole in it you would need to add another sheet below the existing floor and copy the existing floor (without the hole in it) to the new sheet.
I just drew a new floor. Bu instead of making it a square i simply stopped mi line, drew into the centre, drew the shape of the hole, got back to the start of the hole, followed the line back to the wall and then finished of the square.
Worked a treat.
I tried your Colour Key method... but i just made an invisible circle? Absolutely going to guess I did it wrong.
Thanks for the help!
Good looking map
