Sheet Effects don't apply (anymore)
Hello!
I've got a problem with my sheet effects. I will post the Pictures as Dropbox Links, if it is allright.
I created a Map with CC3+ on the HW Preset. Everything worked fine, so I got this as a result:
https://www.dropbox.com/s/gu8kfmlziqgxf4h/With Sheet Effects.PNG?dl=0
Everything is dandy and fine. Now, a few days later I wanted to ad a little Detail and realized, that it didnt used the Sheet Effects anymore:
https://www.dropbox.com/s/vug13j5sottcv5p/No Sheet Effects.PNG?dl=0
I checked if the SE were disabled, and they actually where. But even after I enabled and redrew the Map it still looked like the Image above.
I didn't really change anything since the last time I used CC3+, or at least I can't recall.
I used the following options:
https://www.dropbox.com/s/7mpqanpy8ft2pm5/Options.png?dl=0
As you can see, the Text should be glowing white, but it doesn't.
What am I doing wrong?
Also the Sheet Effects Buttos isn't visible, even though it functions normally. But that was the case from the beginning.
Could it be because I didn't install CC3 beforehand? I thought the CC3+ was a stand alone.
Thanks for your help!
Fuma
Fuma
That you cannot see your sheets and effects button is an indication that you don't have the latest update though, so you should install that.
No my MERGE layer isn't hidden.
https://www.dropbox.com/s/hqzf3vafjzpvmoa/Merge Layer.png?dl=0
Update got installed. Button is now visible. Thanks!
I guess it's less work to fix the old thing than to copy a new one. Also I don't seem to get that working as well.
*sigh*
I just kinda hoped there would be a way to fix, rather than work around, it.
But I can't drag it in another Window nor am I able to open another Map in the same Window.
I'm sorry to bother you so much. I'm really new and this is my first map.
And yes, you will need to use clipboard copy (Edit --> copy or ctrl+C), then paste it into the new map. You cannot simply drag the contents. And keep an eye on the command line while copying. Many people fail to do clipboard copying because they don't look at the command line, and therefore never actually completes the command.
Still weird.
At least it is good to know a work around. If I find out why it happened I will tell you!
Happy Mapping
The problem occured because I did not hide the "template" Layer. That was pretty much all.
Just thought I let you know!
