Mapscale, Map print and Greatings!
Hi to all!
My name is Enrico and i'm Italian! Sicilian precisely! Please forgive my bad english! I'm not very good with it! I have few but important question because i can't find the anwser in this forum (probaly i'm and idiot! =P)
1: How i can set the Mapscale directy in A4 forma? I want use this wonderfull program for create D&D 3.5 battlemap! I need Grid for the miniatures with the right side! How i can do it? Where is the setting? And what i have to do precisely?
2: After those, i need to know how i can print the map correctly! But i think if i set correctly the map first, this point is useless!
3: Greatings to all!!! Be patient with me! I'm not good with this Language but i try hard! =P
Here is a Battlemap Tutorial that may be of help to you. :-)
http://forum.profantasy.com/comments.php?DiscussionID=5869&page=1#Item_0
2. When printing, find the Scale settings in the print dialog. Enter 1" in the Paper distance box, and 5 in the drawing distance box. Make sure that the 'Scale Factor' option is the one selected as well.
I'm terrible i know! But i want learn!
2. The print scaling options are set in the print dialog.
When you print using the settings specified above, each grid cell should be 1" on paper, which is the most common size of physical battlemaps.
