Question
I was using CC3 to place objects on the old Iron Crown Enterprises Map of Middle Earth (the big map of the continent) I was placing mountains and other stuff and saving each time. I have now come back to it but when I load it I see all of the things I have placed on the map but the map itself is gone and there is just a big red "X" that covers more than half the map, I used Photo shop to first save the map as a .bmp and after each session of working on it, what am I doing wrong?
- If the path starts with # then the path begins in the installation folder.
- If the path starts with @ (CC3+ only) then the path begins in the CC3+ data folder.
- If the path starts with $ then the path is the same as the one for the map you're editing.
Cheers,~Dogtag
