Selectivly deleting rivers from FT3 overlay.
After I generate rivers in FT3 is there a way that I can edit the rivers generated and selectively remove / delete some of the rivers? Also in a way that the rivers deleted will not just be hidden so they still export to CC if I were to export a region where I removed the rivers.
Thank you.
Create (or show if already existing) the river exclusion mask image overlay using Tools>>Rivers>>Enable River Exclusion Mask.
Use Image Overlays>>Overlay Paint Tool to paint areas where you don't want rivers to be generated.
Generate rivers normally; rivers will not be routed in the masked areas.
You can use Tools>>Rivers>>Remove River Exclusion Mask to hide the river mask and Tools>>Rivers>>Enable River Exclusion Mask to show it again.
If you would like to permanently remove the river exclusion mask, use Image Overlays>>Show Overlay Window and delete the overlay named "RiverExclusionMask".
Following instructions above still results in no rivers anywhere.
What I am missing?
