vari-color fog/clouds ?
I am definately not an artist...
I was wondering if anyone has vari-color clopuds and/or fog in the works ?
That would help with some dungeons I'm working on. The Annual Issue 99 Alyssa Faden works for white/gray clouds/fog, but not otherwise. I know I could wangle tyhem around and make the vari-color... but I think it would be great if there were some vari-color ones made from scratch.
It really doesn't take much artistic skill - just a straight line in most cases.
Works best with a blur effect that is at least as large as the line width - eg if the line width is 10 units, set the blur effect to be at least 10 units, preferably slightly more.
[Image_7210]
FOG_White
[Image_7211]
FOG_Black
On a sheet with a large enough blur effect to loose the detail, so that you end up with something like this smoke plume from Merelan City:
[Image_7212]
The smoke stack is on two sheets. The black smoke is FOG_Black on a sheet below the white smoke, which is FOG_White. Both sheets have the same blur effect. I haven't used any fancy drawing techniques. These polygons are totally basic in shape - a couple of splodge shapes - like the clouds in a child's drawing. It is the transparency of the textures that allows the black fog to show through the white fog in that curly way that smoke has about it.
Incidentally - the seaweed in this extract is FOG_Black, but its placed on a sheet with the very tiniest amount of Edge Fade Innner, and an RGB Matrix Process effect that turns the black reddish brown.
Both these textures are ones that I created myself in Corel Photopaint. They are free to use, but not for resale - in other words you can do what you like with them, except sell them on as textures in their own right. Incorporating them in maps for sale is perfectly fine by me.
Just saying that here while I remember to tell people about it. You could very easily create your own perfectly seamless swirly scribble thing like those I've uploaded above in about 5 minutes flat - by just scribbling in circles on a single transparent layer
And this would be for isometric maps, not overhead. But I may be able to figure that out. Punt ! :-)
DD3 Color also has a nice Green Fox that I have been toying with.
SS2 Bitmap A also has a greyish fog.
That only gives white, green, and grey.
A variable color Fog would be nice.
You could probably use any color poly with edge fade and transparency to create fog affect as well.
I've tried to use it myself a little bit, but my lack of artistic talent shows a lot more with such a tool than in CC... But I think you might do quite well with it!
I could start a thread about all this stuff, but I'm not sure that its really very relevant to the PF forum, and might even confuse some of the newer users. That's why I've gone a bit quiet just lately - but I am here - watching and diving in every now and then
EDIT: I am however, seriously impressed with the texture making facility in Krita
Other than that it works well
