Grid not matching up.
I need some help. I am trying to have the Grid 10'x10', and the tile match up. But it wont... What do I need to adjust?
Please see attached CC3+ file.
Thank you for your help.
    I don't know if it is possible. I was going to suggest slightly changing the value of the fill scaling to match, but I am unable to find a fitting value. I am guessing there is a loss of precision in some formula in the engine that causes this.
    I'll instead recommend that you use the flat stone fill instead of the tiled one, and then use a solid black grid with a gridline width of about 0.05, and apply a weak black glow to the grid. This will cause a similar effect to using the tiled fill, but since it uses the actual grid for this task, you won't have to deal with the issue of not lining up.
    If you want to, you can also have two grids in the drawing, one purely for the effect, and the other your normal grid.
  • I will give it a try, thanks for the help, I'll let you know how things work out.
  • That did it Monsen, thanks so much for the help, I appreciate it.
