How do you keep the outer contour lines after adding more land & remove the new contour lines inland
New CC3+ user here.
I know I have another thread going about something else but this is something I was trying to get to work as well and couldn't figure out. So I thought I would ask anyway.
I was wondering if there was a way to keep the contour lines of an island while at the same time adding more landmass to the island to give it a different look. Then remove the contour lines that show up inland from the new piece of landmass you just added. Is there a way to merge all of them together? I see a merge layer not sure if that is where I would try to do this or not.
Would I use send behind to do this?
Or would I just go to edit/reshape/stretch?
Also how do I erase an edge or part of an island without erasing the whole island?
I like the contour line look on the outside edge of my island is why I'm asking.
I scrambled some landmass on an island as an example and attached a FCW of it so you can see what I'm talking about.
(this is particularly more helpful from my point of view, since I am currently working on a very large and complicated map that I have to keep closing down if I want to look at your map in between times)
Do you have a screen shot to show us what you mean?
This is just an observation here: I have a feeling from the way you are talking about layers all the time that you may be placing more importance on them than they deserve. While they are sometimes important for freezing certain aspects of the map to make drawing easier, the sheets are far more important and powerful than layers. Sheets are the CC3 equivalent to PS layers, while CC3 layers are something else altogether
Removing part of the land is usually done by moving the nodes, using the move nodes tool, or by freehand drawing the new bit and then redrawing the land by tracing the original as far as it remains, then tracing the freehand drawn line instead of the bit you want to get rid of, then deleting the original.
Those weird rivers are part of the blue coastline and will be on the coastline sheet. Try hiding everything else except the coastline sheet and seeing if you can dissect the intruding lines.
Failing that, try tracing all the way around the entire landmass to make it one block instead of many, and delete all the smaller blocks.
I might, however be wrong on all those counts, since I seem to be having a bit of trouble deciphering your questions - probably because I am as usual over-tired
Thanks again
Well done
