My first map - cultssecret basement below a mill
Just thought I would share my first map - I'm new to CC3+ and also to dungeons and dragons in general so I am putting together my first adventure. The basement is a lair for followers of Malar - the cells are actually kennels. The entrance is going to be through the cobbled room which is the mill basement. The shrine area will be hidden and is overgrown as I have another character that is using them to his own ends and raising Blights (need to add in symbols etc!). Anyhoo its a bit of a complicated story that i won't bore you with - just thought I'd give a bit of a s
setting. My first map - having done a few of the tutorials and spent a while playing with lighting effects.
I am looking for advice/tips and, of course, anyone willing to say nice things too
J
J
#1 so someone doesn't steal your hard work without permission. Though I am sure no one here would do so.
#2 not everyone will have the symbol sets and other add ons to see the entire map.
I opened it and it was about 50% red X's
You can render a jpeg image directly from the map by using the Save As option, and changing the file type to suit.
If you need further help producing an image please let us know
Thank you both for replies. I doubt anyone will want the FCW really (I am pretty new to this!) but if they do or want it as abase to do something with then very welcome!
Thanks again!
J
You seem to have mastered the lighting set up straight off. That is very generous of you to offer the use of your FCW like that. I am sure there will be quite a few GM's that would like to take a peek at how you did it
I would ask for anyone who might know to explain/advise on one or two problems.
Small symbols - my main symbols such as tables cast shadows. But I can't seem to get items on the table which would cast smaller shadows to cast one unless I really ramp up the shadow length to the point it looks daft.
How can I get the outside to show? Is there an easy way? Obviously no lights outside but if I put light finalise on the background layer is have to move it above the dungeon for it to show - thus obscuring everything. Can't think of an obvious solution if I want to show surrounding details.
Lastly - lots of people's work on here has some amazing floor types - tiled etc. I don't really have much of a range even with the add-ons mentioned.
Thanks again and in advance!
J
I don't have any of the other collections on my system, so I wouldn't know if there is another vast store of them anywhere else. I suspect there will be, since CSUAC and Dundjinni collections are pretty vast.
Thanks for the tip!
J
Click the box where it says "FS:..." at the top on the right of the screen, then select the bitmap fills tab and then choose the fill you are using for that floor from the dropdown box. You will see that there is a 'scaled' tick box, which I suspect is not ticked in your case. You need to tick that box and type in identical x and y values for the scale. Try 20, or 50 to start with and see what you get when you click ok, as the fill will adjust itself to the new fixed scale values you have just entered.
You won't get it right first time just by guessing, but the first guess will give you a benchmark to start with. All you need to do then is work out how many times smaller or larger you want the tiles to be (roughly) and repeat the process, adjusting the x and y values accordingly. Halving the values will halve the size of the tiles. Doubling the values will double the size of the tiles.
(Let me know if I'm talking a load of nonsense. I'm not always great at instructions
Thanks for the help!
(I think that's more excitement than a person should probably get from tiles).
J
And everyone is entitled to at least one little distraction in their lives
