Map enlarge
Is it possible to change the map size after it is created. Example. Lets say I created a map that was 500X300. After I drew the map and decided I wanted to add more, could I make it 1000X800?
If so how can I do this?
Thanks in advance
Thanks in advance
1. Simply erase the current map border and draw a new one. The actual canvas is almost limitless in size, but drawing tools constricts themselves to entities on the MAP BORDER layer, giving the impression of a limited space
2. Start a new map in the desired size, then use clipboard copy (Edit --> Copy) to copy over the entities from your old map to the new one. Make sure to watch the command prompt to ensure you actualy fiish the copy command before trying to past it into the new map.
i choose
edit->copy
i select all the old map
then click Do it
when i come back to work on the new map, trying to paste the old into the new, it says "clipboard is empty"...
When you use the paste command in the new map don't bother trying to position it by hand, just enter 0,0 again and it will paste exactly at the origin.
If you don't want it at the origin then you might want to paste it by clicking the map - either way, to have something to paste you need to complete the copy process first
Sorry.....i lost the last passage....now it worked!!!thank you!!!
