Tiled printing cutting off 5' when printing
 JoeyD473
                Betatester 🖼️ 2 images Traveler
JoeyD473
                    I printed a map using the print wizard to tile it. It keeps cutting off 5' on the right side of each page and I can't figure out why. I have attached the map.
The Print Settings:
View: Everything
Scale: 1:60
Page Size Letter
Layout: Portrait
Margins: 0.13(all 4 sides, its what I use in Word as well because it is what the printer prints)
Tile Print: Set N tiles based on scale
            The Print Settings:
View: Everything
Scale: 1:60
Page Size Letter
Layout: Portrait
Also, if you specify an overlap, you can also use that as a workaround.
I tried running your map on my printer, and couldn't replicate the problem (had to use the appropriate printer margins for my own printer obviously, and didn't have letter paper, that stuff is difficult to find in stores, so the test wasn't identical).
'Fit to page' usually works for me. Sometimes I have to use 'shrink to page size' or something similar.
