Perspectives 3 and Dungeon Designer 3
Just a quick question. If you have designed a map in DD3, is there a way to import/convert to PER3 without the need to rebuild the map in PER3?
I'm guessing the answer will be no, but one can hope
Check out the PER3 Essentials guide for a tutorial on converting existing floor plans into PER3 maps. They start on p. 14 but if you haven't read through the Essentials guide, I recommend the whole thing. It's short, fun, and chock full of useful information.
A PDF version should be in the Documentation subdirectory of your CC3 data directory but, if necessary, you can download it from the Perspectives 3 section of your ProFantasy Product page.
Cheers,
