Installing Fractal Terrains 3 on a Mac using Crossover
Hi Everyone! I'm new to the boards and the software and could use some help. I use a Mac and the Crossover to use CC3+ on my computer. I was able to install CC3+ and the demo of Fractal Terrains 3 on my computer without any problem. When I tried to install the Fractal Terrains 3, it seemed to install alright, but when I try to open it, it appears for a few seconds in my dock and then just disappears. I attempted to install it using various "bottles" choosing the various operating systems, but without any success.
The demo version works wonderfully. Any suggestions about what I could do to make this work?
I have never used a Mac, and don't really know anything about what might be wrong, but when installing on Windows we usually turn off the antivirus software for a moment and right click the installer to install as Administrator.
Obviously I have no idea how this would translate to Mac installation, but I thought it might help if you knew how Windows users achieve a successful installation
Rob
Rob
I can install FT, it just doesn't appear to run when I start the program.
second what "bottle" are you trying to install in ? i would recommend a windows 7 32 bit as others are a little flaky, the latest setup from the downloads is 3.0.20 and installs fine , it adds in the relevant runtime c++ library which is 2015 (14)
one thing , when the setup window finishes and asks if you want to run it now , uncheck the box to say no and let crossover finish its work and click the crossover done button
FT3 can live in its own bottle or within the cc3 bottle
hope this helps
Rob
I'm using a previous version of Crossover (14).
My Fractal Terrains and Fractal Terrains Pro apps will install and run, but not Fractal Terrains 3. This is the same issue I was having last summer when we were testing it and I couldn't run it... I'm just getting around to trying to fix it now.
Rob
Microsoft Rich Edit 2.0
Microsoft Rich Edit 4.1
msls31
Uniscribe
Wine Gecko (32-bit)
This because I installed it in its own bottle for this test. CC3+ (Windows 8) has many modules as well as Microsoft Visual C++2013 (and 2015). I installed FT in that bottle earlier but same problem.
the Wine Gecko (32-bit) is there below the picture
Rob
