Feature Request - Duplicate sheet (or sheet effects)
I would love to be able to duplicate a sheet with the effects in it in order to create a new sheet...
Example: City Walls Sheet in CD3 Style #2. When you use the draw wall tool, it draws to 2 sheets. (WALLS and WALLS TOP). I use similar sheets to do towers. I would want to have towers low and towers high, so you have to create sheets for both types, and put in the effects. It would be a lot easier to simply duplicate the sheet and rename it.
The same is true for background sheets. Sometimes I want to create 4 or 5 with similar effects to design the background.
    Yes, this has been on our wish list for a while. Ideally you could simply duplicate a sheet, or copy & paste sheet effects from one sheet to another. Unfortunately, at the moment this is not possible.
    Though I just had an idea to help out a little:
    - Open the sheet effects dialog.
    - Save your current effects under Effects Presets (use a new name if you have made changes from the template).
    - Rename the sheets you want to duplicate.
    - Re-select the Effects Presets from the dropdown list. DO NOT save the current settings when asked, but allow the old sheets to be added.
    You now have a copy of your original sheets with the same effects, you just need to move them into the correct position.
  • I'll experiment with that. It will be cool if I can do that.
