Symbols change to default
Hello! I have been using CC3 for some time now and recently I have begun to have some problems. I am currently running CC3+. I then create a new file for overland mapping. I pick a predefined style set. I lay out some land using the fractal landmass tool. I lay down some mountains. Then I switch to my water symbols and that is when the problem happens. It reverts to the default symbols. I switch back to mountains, and again the mountains I had been using are gone, and the default mountains are shown. Has anyone else had this issue? Any idea what caused it?
I am now having an issue with CC3. I would like to use it to get some of the older annual styles, and I have tried starting it a few times and get fc32.exe has stopped responding. I have restarted, and I get the same error. Any idead?
Thanks,
Nick
Thanks for the help,
Nick
I can usually load the map causing the problem after that, from within CC3. I then, before saving the problem map, try to find the problem. I"m not always sucessful, but I go back and try after a day or two and look at it with a fresh outlook.
