Tome all dungeon drawing tool question
I understand the basic concept for changing the all dungeon drawing tool to create new drawing tools. I'm attempting to make a drawing tool for a walled cave. The Tome showed me exactly how to do this. However, in the dungeon drawingtool, the floor I want for my cave isn't listed as one of the options. I want to use the dirt bitmap that doesn't have a numbered behind it, and I want to make it walled. I know how to make a walled drawing tool, but I don't know how to make a drawing tool with a different floor than what is listed. Anyone know how to do this?
Note that if you make a drawing tool with a fill style that is not in the template by default, you must import it into every map before using the tool in it. (If you use it a lot, you can also make a new template with this fill style already defined.)
Follow up question- if the fill is not part of the template, but IS a profantasy bitmap, will it cause red x's in my fcw for anyone.that hasn't imported.the fill?
If it doesn't show up, can you send med the map file in question, and the file for your drawing tool, and I will have a look. No, not as long as they own the product the fill come from. The definition is stored in the map, not in the program, so everyone who gets a copy of the map will have the exact same fill style ddefinitions in it as you have.
