Can't install Perspectives 3
                    Hi all
I can't install the per-cc3-compatibility.exe.
Error message:
Sorry your CC3 installation could not be located.
Please install and run CC3 first.
Environment:
Windows 10 64-Bit, latest updates
CC3+ version 3.74
Installation path is pretty standard: "C:\Program Files (x86)\ProFantasy\CC3Plus\fcw32.exe"
Program has been started several times as suggested in other topics here and the computer has been rebooted.
There is also no way to help the program to locate the installation.
I have seen several posts with the same error message for other addons. None of the tips really did the job for me.
Please help me.
Error message:
Environment:
CC3+ version 3.74
Please help me.
Its on that same popup in your account.
So this is all I got:
Perspectives Pro downloads
Setup program to install with CC2-Pro => Install this one for your CC3-Pro
Essentials booklet PDF
Setup compatible with CC3 => This is the one I tried to install before "per-cc3-compatibility.exe" which seems to me to be the more correct one if you follow pure names.
Since CC2 is 8 years old or so, I really did not even consider to install that one, afraid I would ruin my top up to date version 3.74.
I was right, while this version installed without any problems, I ruined my CC3-Pro installation. It now starts with an alert and perspective does not work either. (See attached Alert.)
Also the add on does not work, only indicator that it is installed is this message. So I think I simply lack the correct downloads. I only have the CC2 pro one and the CC3 one and a pdf.
So yes I think I am beyond help if I don't get the correct download. I bought this one in spring 2016, so it should be compatible with my CC3 pro 3.74. I don't understand why I don't have access to the correct version.
Also note that Per 3 is a very new product, the pre-released was released in around May, and the full release in July, so if you bouth perspectives before that, you haven't bought the CC3+ version yet, so if so, you need to buy the upgrade. Note that ProFantasy has a 3-month upgrade protection, so if you bought it less than three months before release, the upgrade should be free (This should be handled by the store automatically if you initiate the upgrade from the offers tab on your registration page), outside the free upgrade period there should be a considerable discount.
I am not sure exactly what products where listed in the store that day, perhaps you accidentally bought the wrong product? As mentioned earlier, Perspectives Pro (Which you have) is for CC2/CC3, while Perspectives 3 is the new version for CC3+. I think you should contact the ProFantasy Order desk and explain the situation there, they can probalby sort this out for you.
