Can someone render this to PNG?
Attached is a DD3 map of a dark attic in a haunted house. Everything is very simple except for the lighting. I'm using lights and Wall Shadow Finalize effects. It all looks fine to me but I cannot save it to a PNG with the shadow finalize effect on. When I try it runs thu 4 passes for about an hour before I give up. If I turn off the one Shadow Finalize effect it saves in a minute.
Can someone point out my mistakes or render this for me?
I want a rectangular PNG 24bit, default compression, 2200 by 1400. Crop the single room leaving one square boarder around for 22 squares by 14 squares.
In the meantime, have you tried Simon's suggestion of exporting to PNG via PDFCreator?
On CC3 print screen: Fit to Page and Tiling 1 and 1. Properties--Advanced DPI=300
With PDFCreator: Use 300dpi.
The resulting image at 3050 x 1930. This is plenty for online use.
