Town of Knavesthorpe
This is the home base of the adventurers in the campaign I am developing. Its a work in progress. I am looking for any tips or advice if there is something really wrong. I saved this as a PNG at 1000x800. Should I have saved it as something larger or smaller to make the streets look better?
I'm curious to know, what is that in the upper left corner?
I like this map, and the Jon Roberts style. As a WIP, I don't know what else you're planning but here are some of my thoughts. You might consider adding some trees peppered throughout the city here and there, besides the collection on the left (west?) side. Are you planning to add more buildings between the walls and the street? You may want to add some more outside the walls, too, as well as streets outside the walls for traffic in and out from the outlying buildings and farmland.
I hope you'll share your next iteration too!
Cheers,
The scale of the texture you are using for your road looks way off. I would recommend reducing it significantly. (The 'Scaled' option in the fill style dialog). If scaling isn't enabled for that fill, enable it, and find a reasonable value.
