Question about exporting an inserting images
Question,
1st:
How do I use coordinates to export a portion of the map that is a specific shape & size (exact square) to an image (such as a PNG)?
2nd:
How do I then insert that image into the exact same coordinates on another map at the exact same shape & size?
Thanks,
Charles W. Robinson
    edited August 2016
    Here's one way to export using coordinates.
    Try this:
    1. Move the cursor to the lower-left corner of the area you want to export. Note the coordinates in the status bar (upper left).
      You'll need these for, both, the export and the import. If desired, do the same for the upper-right corner, but this is unnecessary if you know the length of the sides for area you want.
      Note: Be sure the coordinates in the status bar are the absolute coordinates. They should begin with T: and not some variation, such as @T: or >T:. Click the coordinates in the status bar to toggle the format, if necessary.
    2. Select File>Save As from the menu bar.
      The Save As dialog box displays.
    3. Choose one of the Rectangular section options from the Save as type drop-down list.
    4. Set the File name and Options as desired, and then click Save.
      The dialog closes, the cursor changes to a cross-hair, and the Command line reads, Pick first corner.
    5. Type the coordinates for the bottom-left corner, using the format X, Y, and then press Enter.
      The Command Line changes to read, Opposite corner:
    6. Type the coordinates for the upper-right corner, and then press Enter.
      Note: The second set of coordinates for a square of n length per side will be X+n, Y+n because 0,0 is the lower left corner of the map.
      CC3 saves the exported image.
    Yikes! I have to run to a lunch meeting. If no one else tackles the import part of your question before I get back, I'll give it a shot then.
    Cheers,
    Hmmm... I don't use exact locations.
    But here is what I do.
    1) I mark off the area I want to export with a hollow rectangle/square.
    I place text inside th square that gives the dimensions.
    2) I save as rectangular png and use the hollow square/rectangle as a guide. Snap can help with this.
    3) Start a new map with a template size the same as the export.
    4) I create a bmp layer and sheet. Insert the png with that layer and sheet active.
    5) Click on upper right corner, just past the edge of the map border. Hold down the Ctrl key so the inserted file will go where yu want it to. Click on the lower left corner, just past the edge of the map border. Mae sure ortho and snap are off for this.
    6) You now have the inserted file on top of the new background.
    As I make the new map, I hide the bmp layer so I can check on prgress as everytime you refresh, what you have done disappears behind the file you imported.
    edited August 2016
    Okay, as promised, here's one way to import using coordinates.
    Try this:
    1. Ensure the coordinates in the status bar are the absolute coordinates. If necessary, click the coordinates in the status bar to toggle the format.
    2. Make sure the correct sheet and correct layer are active.
    3. Select Draw>Insert File from the menu bar.
      The Insert file dialog box displays.
    4. Navigate to the location of the file you want to import.
      If desired, click Bitmap options and choose transparency and file reference options.
    5. Click the file you want to import and then click Open.
      The dialog closes. CC3 may display a message asking for path information. If so, choose the option you want and then click OK.
    6. The cursor changes to a cross-hair, and the Command line reads, First corner.
    7. Type the coordinates for the bottom-left corner, using the format X, Y, and then press Enter.
      A thumbnail of the file you're importing displays at the location you just entered. The Command Line changes to read, Second corner (SHIFT - rotate, CTRL - allow distortion).
    8. Type the coordinates for the upper-right corner, and then press Enter.
      Remember: The second set of coordinates for a square of n length per side will be X+n, Y+n.
      CC3 resizes the image so the upper right extends to the second corner you just entered.
    This works for me in a quick test, but I've never used coordinates to export or import (other than just using 0,0 as a universal reference). As Jim pointed out, though, there are other ways to export and import files, but the procedures above, using coordinates, worked for me in a quick test.
    Cheers,
  • Thanks Dogtag and jimP! I have a blank copy of my world map listed as Template and then the version I am working on. Since my world is so big, I will exporting image files from the working version to my template version. This allows me to get around the issues with too many nodes and symbols.
    When I got tired of trying to go from over 1,000 small maps to one large map... I chose to use FT3 to export a rectangle. Then I took thayt fcw and cut out pieces of it for region and nation maps. Worked better and faster.
  • Thanks Dogtag! It worked great!
    edited August 2016
    Woot!
    If you're going to continue with this strategy, then you may want to keep a record of the coordinates you've used/exported, and which areas they apply to, so you know or can determine the coordinates for adjacent squares.
    Cheers,
  • Oh, it is pretty strait forward. I place a grid down that is 200 by 200 and use snap & grid. I go to the area I want to copy and it takes me right to the two coordinates that I need. It is real quick and easy and the image on the new map are really nice and crisp. At 200 by 200 I can put the export at 8000 x 8000.
    Nice. I hope your computer's RAM can keep up!
  • Here is a scaled down version of the image:
    Okay, I guess I was confused. I thought you were talking about a world map, made up of regional squares.
    edited August 2016
    Okay, now I'm more confused. What was that you posted? It looks like a regional map.
    Are you talking about a global map? Made up of regional maps, each 8,000 x 8,000 pixels?
  • Yes
    Think patchwork quilt.
    What I posted was one square in that quilt.
    It is a way to get around some limitations in making a very large map.
