Can you change every insidence of a color to another color
I'm trying to change most of my instances of light blue (for water) to light green for land. Is there a way I can select all instances of that color and then change the color property to a different one?
I tried selecting for one of the areas and change the area. PS I think the light blue is one big area with a land mass on top. (drawn with fractal terrains and converted to CC3 map)
Try this:
- Click the Change Properties button
- Right-click and select Color from the pop-up menu.
- Right-click to accept the default, shown in square brackets. In this case (and in several other cases) the default is to display the appropriate dialog so you can choose a value.
- Click the color you want to select (the one you want change) and then click OK
- Right-click and then select Do It from the pop-up menu.
- Change the properties you want and then click OK.
I hope that helps.The cursor changes so you can select entities.
The command line changes to read, Color # [dialog]:.
The Select Color dialog box displays. Alternatively, if you know the color number, you can type it and then press Enter, and then skip to step 5.
The dialog box closes and the command line now reads, Select entities (X picked):, where X is the number of entities that were selected.
The Change properties dialog box displays.
The dialog box closes and CC3 makes the changes you entered.
Cheers,
It looks like I'm going to need the color number to select with. How do you view the color properties on an specific symbol?
That said, you can't change colors for symbols, unless they are varicolor symbols.* Likewise, you can't change the color of entities that use a bitmap fill. The instructions above are for changing the color of solid-filled entities.
Cheers,
* Technically, there are ways to modify symbol definitions and bitmap fill files, but that gets more complex than using the Change Properties function directly on the object you want to change.
