Area of a Surface in CC3
Hello, I am very new. I have a question that I've been trying to find the answer to, but I've only found posts saying that there is a way to do what I ant, but I can't find how.
Anyway, with CC3+, is there a way to measure the area of a piece of land? Like if I have a country with clear borders, can I find how much surface area it covers, or at least the % or something? I've been looking for this answer all over the place, and the closest I got was a post where someone was trying to do it it Fractal Terrains, but a response said that he could import it to Campaign Cartographer because there was a tool for that there.
If there is a tool, for some reason, I am incapable of finding it, as I just spent the last 30 minutes exploring the program with no luck.
Or if I can't do this, then is there a possible method to use without Photoshop that could accomplish the same thing.
Thank you for any help you can provide.
Thank you so much! I suddenly feel so much better.
In the same "info" menu, just select "list". Then select your entity (you will probably have two entities if you draw it with the tool, it's not a problem). Right click, do it. A windows will appear with lots of information about the selected entities. Among those, the length of the entity, and its area.
If an approximation is good enough, you can start the Area command, and instead of selecting anything, just use it to "draw" an approximation of your landmass, using the existing territory one as a guide. The closer you follow the original, the more accurat the result becomes.
Does that help?
