iso Annual glow areas ?
I want to place a pillar/arch way on one of my Iso dungeon rooms for my Arcology.
When I try to place a multipoly, its looks wrong, very wrong.
before and after pngs. I know I added a bitmap fill using Perspectives, but this is Annual 66, Isometric Dungeons.
Going by the title of your thread, Jim, is it that you want to use the polygon to make a glow in the archway?
So it looks like a ghost or a dimension gate kinda thingie.
Heck, depending on the effect you use, you might even be able to just use a 0-width path.
(Click an image for a high-resolution version)
Cheers,
Note: The attached CC3 file uses templates and symbols from Cartographer's Annual Issue #66. If you open the file in CC3+ or if you do not have that issue of the annual, the map will not display properly for you. However, the glow is just made with the Polygon tool so you can still see it and the layers, sheets, and effects I used.
Other games I've played, The Fantasy Trip for instance, has lots and lots of Gates/Portals.
Oh, I'm making maps for Tunnels and Trolls and TFT to. Not much there yet.
Cheers,
