Edit change text after it's placed
                    This might be obvious, but I can't figure it out. If I placed a text that says "Snowport", and then I want to change it to "Stormport", how do I do that? Thanks!
L.
                            L.
Alternatively, just type Edit, press Enter, and then select the text.
You can also select Edit>Text>Edit Text from the menu but that strangely requires the extra step of right-clicking and selecting Do It from the pop-up menu after you select the text, where Numeric Edit (Edit) lets you edit the selected text immediately.
I hope that helps.
Cheers,
