DD3 Vegetation Catalog
I may just be missing this, but when I click Symbol Catalog Settings, it doesn't list the DD3 Color Vegetation catalog. I've attempted to go through the CC3 User Manual to figure out how to get it to show up, but it's eluding me. It's available per the instructions in the DD3 Essentials pdf, but I'd like to be able to access it without having to manually load it each time I need to add some trees or bushes. Is there a way to do this?
    Currently you have to manually load the catalog into the catalog window (through the Open button above the symbols).
    But you can do the following to make the Vegetation catalog show up in the Symbol Catalog Settings:
    - with a "DD3 dungeon" map open, start the Symbol Catalog Settings
    - click the "Advanced" button
    - select the "DD3 Color Skirmish" setting
    - click the "New" button
    - type in a new name, e.g. "DD3 Color Skirmish Vegetation" (that way the setting will show up when you click the Skimirsh catalog button)
    - "Browse" to the vegetation catalog and open it
    - save your new catalog settings.
    The catalog should now show up as an option if you click the Skirmish button or All Catalog Settings.
    Hope this helps.
