Ghost lines
Loopysue
ProFantasy 🖼️ 41 images Cartographer
While working to perfect the (not yet very perfect) relief mapping of a new version of Errispa, I have finally managed to capture two screen shots of the vanishing horizontal lines that sometimes appear.
I also know that these are caused by changing the fill properties of shapes imported from FT3, in particular for the climate.
Here are the horizontal lines I wasn't able to capture for you before:
I tend to work on a sheet above everything else, called "sketch", so I don't loose the line as soon as I've drawn it beneath everything else.
And yes, this map is still in the very early stages, which is why there's still something a bit wrong with the relief work - hence the desert rolling down over an apparent cliff!
