Trace is looping the wrong way?
                    Hi, I bought CC3+ today, and I'm working through "Our First Map" tutorial. In the Terrain Features section, step 12, it's showing me how to trace to an entity. However, I found that 90% of the time, the trace is connecting the points by the long way around. It works correctly sometimes, for no obvious (to me) reason. It's unclear to me whether I'm doing something wrong or if it's a bug.
Edit: Ah nevermind, it is mentioned in the tutorial. I overlooked it because the tutorial tells you to go to points A-B-D-C-E, instead of the usual order. All sorted now
I have put this down to my tendency to go tearing off far too fast for my laptop processors to cope with my insistence that we 'do it now' - all four of them.
If you have this problem (which admittedly isn't exactly the same as the one described by Lucky above), you can trick your poor overheating laptop into going the right way by actually setting off in the wrong direction first, just by a couple of points, then, when the trace has gone all the way round and back again, you can back up and go in the other direction and get on with tracing the half the coastline you were intending to trace in the first place. It doesn't work every time, but about 7/10 times.
