Changing Style Sheet after Export from Fractal Terrain
I am having problems getting "Overland Mike Schley" to show up properly when I export a map from Fractal Terrains 3. I am using CC3+
The correct image / bitmap for things like the drawing tools such as "Terrain Default, Farmland" if you go into "Advanced" ->"Properties" the fill style is blank. Furthermore the correct fill style is not accessible.
Can anyone tell me how to change the map I'm building over correctly please?
  • I was able to figure it out after trying stuff.
    Basically I had to make another temporary map using the template I wanted to use, and then I just made a quick little island and added the misc terrain types etc I wanted to use. I then copied those entities from that file to a random spot in the map I actually wanted to use. Once I did that I was able to use the different "Drawtools Style"
    Yes, that is usually the best method: Start a new map in the style at the size you need, then copy things over from the FT3 export as you need them.
