Strange blue line
                    I recently decided to try CC3+, and while I'm working my way through the tutorials, I noticed an anomalous blue line showing up. I have replicated it several times. It shows up when I begin a new map, probably in about 40% of new landmass creation. It always seems to be somewhere in the top 5-10% of the landmass, and can't be erased. The redraw command does not solve the issue, either. Has this occurred to anyone else? If so, how did you fix it?
http://forum.profantasy.com/comments.php?DiscussionID=4872&page=1#Item_01
I wound up coming up with a different solution: I deleted that blue coastline. Hide all the sheets save the one holding the coastline, then select the coastline and delete it. I then used the techniques Joe Sweeney describes in this video:
You can see the final result I got here: https://c6.staticflickr.com/1/390/19163028813_c4e7f3800d_z.jpg
To be honest, I like this better than the default electric blue coastline in that style. Also, near as I can tell from experimenting with a few other styles, that problem appears only with this blue coastline. So, rather than spend time editing nodes, I just nuked it.
Hope this helps.
