InstallAware error when installing CC3+
                    I'm having a problem installing the CC3+ software.  I run the program as administrator with UAC activated.  The InstallAware wizard stops after approximately 25% and gives an error that the file is corrupt or the file is password protected.  I was able to install CC3 without any problems but I get the same error when attempting to install the cc3 update.  I'm running Windows 10.  Any ideas?
" Erorr from reading file : ... \HHActiveX.dll - make sure that the files exists and that you can acess "
If i use ignore botton they come more than 30 errors of missing dll files like AlphaBlur.dll or fcw files and so on.
Any idea what i can try? reg scans, celaning pc etc i have try without results. Okay, i read here enable firewall oder protection software i don't try, maybe it works?
What else can i try ?
