Tolkein Font in CC3+ Update 4a Install Issue
The new CC3+ Update 4a does install several fonts and you may need to do this as I had to on my Windows 7 system if you are using Vista.
I checked the files in the installer via unzipping it with 7-Zip to see the exact files it installs and discovered that the Tolkien font is a larger sized and newer one than I had on my system. That font installs with some other ProFantasy installers, but they install an older smaller file size version of the font.
I had to do a command prompt to get into my font folder and make minor registry change so that the newer version would be the one on my system. (older version had a small "t" and latter had a capital "T" so registry entry was changed so it used the capital "T".
See the thread and posts I made about fonts in this thread http://forum.profantasy.com/comments.php?DiscussionID=4325&page=1#Item_7 if you need instructions on running the correct command prompt, etc. to fix font problems if your using Windows Vista & up as the Fony install issue is an issue on newer Microsoft Windows systems.
You'll need to check the fonts and registry entries to see if you need to fix this font and any others
None of the other fonts in CC2+ Update 4a need to be fixed on my system after installing the update, the Tolkein one was the only one that had problems.
